Дата и час: 26 Май 2019 10:37
Часовете са според зоната UTC + 2 часа [ DST ]
 Страница 1 от 1 [ 3 мнения ]
 Заглавие: Видове диференциали на тойота!
Непрочетено мнениеПубликувано на: 10 Дек 2011 21:06
Регистриран на: 04 Фев 2008 22:15
Име: Марин Стоянов
http://home.4x4wire.com/erik/diffs/
 Заглавие: Re: Видове диференциали на тойота!
Непрочетено мнениеПубликувано на: 10 Дек 2011 21:37
Име: Марин Стоянов
Ето и предавателните числа които са най благо приятни спрямо размера гуми:
As always, if you are unsure which ratio to install in your truck, be sure to seek a second opinion.
What you see recommended below, may not be to your liking depending on your driving style.
225/70R-15 Tires = 4.10 or 4.30 gears
31 x 10.5-15 Tires = 4.56 or 4.88 gears
32 x 11.5-15 Tires = 4.56 or 4.88 gears
33 x 9.5-15 Tires = 4.88 or 5.29 gears
33 x 12.5-15 Tires = 4.88 or 5.29 gears
35 x 12.5-15 Tires = 5.29 gears
For factory stock performance, or near factory stock performance with larger tires, selection A should be used with 5
speed manual transmissions, selection B should be used with automatic transmissions. For better off road
performance and better highway acceleration, selection B should be used, but you will experience higher rpms on the
highway than you may be used too. How these ratios affect fuel economy depends entirely on how you drive and the
weight you carry. In some cases a lower ratio, combined with reasonable driving, will return stock gas mileage, on a
truck with larger tires.
When regearing with an automatic transmission on pre-1995 trucks that have larger tires, I recommend going with the next lower gear ratio to
maintain factory performance. I.E. if you have 31" tires, you should use 4.88 gears, if you have 33" tires, you should use 5.29 gears. The
lower gearing is recommended to offset the extremely high 1st gear in the automatic and the high overdrive. Toyota installed 4.30s in stock
automatics, while similar 5 speed models got 4.10 gears. This is not as critical on Tacomas since they have more powerful engines.
Източник:
http://www.brian894x4.com/Gearratiosanddiffs.html
Непрочетено мнениеПубликувано на: 18 Апр 2018 12:31
Регистриран на: 18 Апр 2018 12:28
Skype: maoscow
ПОЛ: loas
МПС: toyota yaris
Това е много добра история.
